Ing. Ervin Zatko EASY Friend
- 6 times in 1 posts
January 5, 2011 at 1:06 pm #158327Hi
I have now 2 problems in this module.
JAsidenews modul get content from my category where I use Blog style.
In JA sidenews I want use small pictures.Problem 1: In introtext is a text {jathumbnail off}
Problem 2: Pictures don’t have border and marginHow I correct these problems?
EASY
aman204 Friendaman204
- January 2010
- 418 times in 356 posts
January 6, 2011 at 7:16 am #3703931) You can remove the specific text from specific article output in article manager
2) Add this at end of template.css file and adjust properties accordingly
.ja-slidenews-item img{border:1px solid #ccc;margin-right:10px;}
1 user says Thank You to aman204 for this useful post
Ing. Ervin Zatko EASY FriendIng. Ervin Zatko EASY
January 6, 2011 at 9:11 am #370425The 2. problem is solved. Thank you 🙂
But in the 1. I can’t remove the specific text, because it I need in blog style. Another solution???
- January 2010
January 6, 2011 at 11:14 am #370451<blockquote>But in the 1. I can’t remove the specific text, because it I need in blog style. Another solution??? </blockquote>
Sorry but I am unsure about this. Probably, Someone else could help you with this 🙂
Cheers
January 6, 2011 at 6:03 pm #370522Who can help me?
thuanlq Friendthuanlq
- October 2010
- 121 times in 99 posts
January 8, 2011 at 3:58 am #370758HI @easypc,
You can remove “{jathumbnail off}” on introtext of jaslidenews module as following
– Open “helper.php” file on location “modules/jaslidenews/”.
– Edit “getListArticles” function, add new code as following after line “$data = $db->loadObjectlist();”
//Start copy
JPluginHelper::importPlugin ( 'content' );
$dispatcher = & JDispatcher::getInstance ();
$params = & $mainframe->getParams ( 'com_content' );
$limitstart = JRequest::getVar ( 'limitstart', 0, '', 'int' );foreach( $data as $i => $row){
$data [$i]->text = $data [$i]->introtext;
$results = $dispatcher->trigger ( 'onPrepareContent', array ( $data [$i], $params, $limitstart ) );
$data [$i]->introtext = $data [$i]->text;
//End here
It call “onPrepareContent” trigger, if jathumbnail was enabled, this plugin would remove custom tag.2 users say Thank You to thuanlq for this useful post
January 8, 2011 at 4:50 pm #370851Great solution 🙂
Thank you very much.AuthorPostsViewing 7 posts - 1 through 7 (of 7 total)This topic contains 7 replies, has 3 voices, and was last updated by Ing. Ervin Zatko EASY 13 years, 11 months ago.
Module jasidenews problems
