  • islandview Friend
    #145093
    Hi there – This Template is looking fantastic!!!!
    A couple of things…
    1) POSSIBLE BUG – According to the Module Positions guide, there is no ‘Left’ position – That’s fine I thought as I have modules in ‘Left’ on my other templates which I have for other areas of my site which I wouldn’t want to appear on Halite… BUT Halite picks them up!!! Should this be happening? If so the Module Positions guide is wrong? Where would I find in the code the bit that picks up modules in the ‘Left’ position – I’d like to take that out.
    2) COLUMN WIDTHS – On looking at some of the page coding, there seems to be code checking for the width setting of the columns – Where can I enter that? I don’t see anything in the back-end paramters….
    Thanks!
    Anonymous Moderator
    #320562
    Hi acbonner
    I would like to answer your questions as follows:
    => In Administrator, go to Extensions -> Template manager -> edit ja halite template. In the edit page, select Default Layout to 3 columns classic. At that time, you can see the left columns.
    => with this template, we are calculating the width of left, body and right columns. if you want to change the width of right column, please open templates/ja_halite/css/layout.css, at about line 74, find following code:
    #ja-right {
    float:right;
    and change to:
    #ja-right {
    float:right;
    width: 340px !important; /*change to your width*/
    islandview Friend
    #320577
    OK Thanks – So just to be clear – The module positions shown in the official documentation at http://www.joomlart.com/templates_club/club_portfolio/ja%11halite.html relate to just 1 of the provided layout views within the template? (If so, which one is this – default.php?)
    Is there anywhere that shows the module positions for all of the layouts provided – or is it just a case of having to go through the code to work out what’s where?
    Anonymous Moderator
    #320668
    Now, we have a lot of layouts for a template. (=> In Administrator, go to Extensions -> Template manager -> edit ja halite template. In the edit page, select Default Layout to 3 columns classic. At that time, you can see the left columns.)
    For the reason, to see all position in a layout, you have to choose that layout and run this link: http://www.yourdomain.com/index.php?tp=1
    danderss Friend
    #321555
    Hi, JA Developer
    If change recording to your suggestion:
    “width: 340px !important; /*change to your width*/”
    Then the column expands,yes. But it also moves the column to the bottom of the page. Below the content. Do I have to change anywhere else to?
    Dan
    Anonymous Moderator
    #321683
    Hi danderss
    When you add this with to the right column, you have to change the with of left column and content column to suitable.
This topic contains 6 replies, has 3 voices, and was last updated by Anonymous 15 years, 1 month ago.
