July 24, 2017 at 9:33 am #1051049
http://farshy.com/ar/
module : أفضل المنتجات
position : sidebare-2
the product in it open error page
http://farshy.com/ar/chandeliers1/modern/fa-22-detail.htmlPankaj Sharma ModeratorPankaj Sharma
July 25, 2017 at 7:42 am #1051287Hi
You can share the credentials of your site in Private reply, I will take a look at this problem.Regards
July 25, 2017 at 8:55 pm #1051532This reply has been marked as private.Pankaj Sharma ModeratorPankaj Sharma
July 26, 2017 at 3:42 am #1051602Hi
Did you remove the module from the site?
I could not find the module with name: http://prntscr.com/g0ch6jRegards
July 26, 2017 at 11:02 pm #1051812Hello
No We did not remove any modules
but it’s name in Arabic
أفضل المنتجات
see screen shot attached
Girgis
July 27, 2017 at 2:43 am #1051854Hi
Can you check it now: http://farshy.com/ar/component/virtuemart/%D9%83%D9%84%D8%A7%D8%B3%D9%8A%D9%83/gl-10-detail.html?Itemid=0
It’s working fine: http://prntscr.com/g0si1rRegards
AuthorPostsViewing 6 posts - 1 through 6 (of 6 total)This topic contains 5 replies, has 2 voices, and was last updated by Pankaj Sharma 7 years, 1 month ago.
module not work
