September 3, 2008 at 6:29 pm #132914
Hey guys!
Absolutely love Joomlart.
Got myself into a little bit of a bind by trying to eliminate some module placements in the index.php file. Everything is showing up fine on a mac for Firefox, Safari, etc…But for some reason, on IE 6 and 7, there is a module position on the right hand side that wants to hug the very top of screen. I’ve looked through the css and it all looks consistent between the column that is acting strange and the other which is identical and right next to it (acting normal). This leads me to believe my issue is in my index.php file.
I’ve included both the css (the relevant part) and index file below. Help! 🙂
The link in question is: http://www.keegandewitt.com
Sherlock FriendSherlock
- 2478 times in 2162 posts
September 4, 2008 at 7:19 am #268684hi
Can you make some screenshots in more detail ?September 4, 2008 at 3:11 pm #268764Thank you for your reply. I’ve attached a screenshot from Safari on a Mac (where everything is fine) and a screenshot from IE on a pc (where the right module is out of line).
Let me know if I can supply anything else that could help.
Sherlock
September 5, 2008 at 8:01 am #268890Hi
edit template.css (line 1426)
.ja-box-left, .ja-box-leftcol, .ja-box-center, .ja-box-right {
float:left;
overflow:hidden;
padding-top:0px;--> add this line
}September 5, 2008 at 3:43 pm #268952Thanks so much for your reply. I changed the code as you reccommended and sadly, there was no change. Any others ideas?
Thanks for trying.
September 5, 2008 at 4:41 pm #268960Hi,
Can you please PM me your site admin account as well as FPT account? Without investigating into the codes, I am afraid that we can not provide any solutionMenalto FriendMenalto
- May 2007
- 531 times in 361 posts
September 27, 2008 at 4:19 am #272638Can this be marked as Solved?
September 27, 2008 at 1:23 pm #272684I wish this could be marked as solved. The edit to template.css listed above did not correct the issue and all of my private messages to the user who requested them have gone unanswered.
Help!? 🙂
- May 2007
September 27, 2008 at 3:39 pm #272699From a quick look at it you are missing a closing div somewhere i think, but to be sure. you can take a full copy of the template and send me so i can test it further
Viewing 9 posts - 1 through 9 (of 9 total)This topic contains 9 replies, has 3 voices, and was last updated by Menalto 16 years, 2 months ago.
