December 18, 2008 at 10:15 pm #136349
I don’t know how it happened, but on my home page, module position user 1 is not showing in the appropriate location. It is down under the line and into the body position along with my content text. I have the RS Slider published in position user 5 and would like the module 1 to show up next to it rather than under it.
I tried to unpublish the module position 1 so that there would be no gap between the slider and my text, but WHEN I UNPUBLISH MODULE POSITION USER 1, MY SLIDER IN USER 5 DISAPPEARS ALSO.
My website is up and running and I need to fix this as soon as possible. I would really appreciate any feedback at all.
Joomla1.5.7
Avian II
http://www.ripplesstudio.comThank you
Rachel 😀Anonymous ModeratorJA Developer
- 2008 times in 1700 posts
December 19, 2008 at 8:41 am #283451Hi rippless,
Maybe you have changed the ja RSSlider module.
Current on the website, i found that it was redundant a </div> tags.Please try install the module again.
Else please send me your admin account via PM to i could check this issue to help you.December 19, 2008 at 4:15 pm #283504I did make a few edits to the Slider module in the code to eliminate the gray thumb border and the features tag…but I don’t think it was anything to affect the modules. It was working after I changed the module a few days ago and only recently have I started having this problem. What should I look for to change the <div> to make it less redundant?
I don’t really want to re-install the RSSLIDER module unless absolutely necessary because I have already made several changes.
If you can’t help me via talking let me know how to send you the information. I would appreciate any fix for this. Thanks for your quick reply!
-Rachel
December 20, 2008 at 4:28 am #283547Hi rippless,
please send me your admin account , FTP account via PM to i could check this issue to help you.
December 24, 2008 at 4:06 pm #283958Thank you so much! What was the problem?
Merry Christmas!
This topic contains 7 replies, has 2 voices, and was last updated by Anonymous 15 years, 9 months ago.
