Ninja Lead Moderator
Ninja Lead
- November 2014
- 3854 times in 3563 posts
April 13, 2015 at 3:42 am #566700@testcouch: Maybe I misunderstand what are you expecting. Please give me the screenshot and description what are you trying to do. It would help to understand the issues and give you specific answers.
testcouch Friendtestcouch
- October 2013
- 9 times in 1 posts
April 13, 2015 at 1:30 pm #566776hi Ninja Lead, ok no problem i try to explain it more visible:
1. how it should look
2. how it currently look:
hope it helps to untertand it better 🙂
Ninja Lead
- November 2014
April 14, 2015 at 3:11 am #566844+ Enable Frontpage module from administrator area
+ Open templates/ja_social_t3/css/custom.css file and add new rule
.t3-mainbody .t3-content .main-content-inner {
padding: 0px 0px 5px 5px;
}.t3-module.module-yellowaftercomponent .module-ct .custom-yellowaftercomponent {
padding: 10px 15px;
Let me know if it helps
- October 2013
April 14, 2015 at 8:37 am #566882hi, thanks for your help. 🙂
but i guess i should add yellowabovecomponent and not yellowaftercomponent in custom.css right?
i have changed this and now it looks better but the module-title (yellow backround) have still a small offset to the left!
Update:
i have removed both css fix from templates/ja_social_t3/css/custom.css because it breaks the complete layout of other content and module parts!
ok please let us thinking different and start from the ground..
- November 2014
April 15, 2015 at 2:28 am #566972You want to change yellowaftercomponent to yellowabovecomponent css class name in this case, you need to add the new css style below into custom.css file
}.t3-module.module-yellowabovecomponent .module-ct .custom-yellowabovecomponent {
padding: 10px 15px;
- October 2013
April 24, 2015 at 12:17 am #568122hi Ninja Lead, can we please start from the ground with this issue? i have done everything you suggested..bud i can’t use your last code because it’s change other parts!
Module Position aftercomponent works very well, but abovecomponent Module jumps to the left! >:(
- November 2014
- November 2014
- October 2013
April 24, 2015 at 9:19 pm #568242hi Ninja Lead, you can’t change padding values for .t3-mainbody .t3-content .main-content-inner to fix a issue with module position. it’s not the correct way because it’s change the components layout for other pages!
p.s. please remove above screenshot
- October 2013
April 24, 2015 at 9:19 pm #733338hi Ninja Lead, you can’t change padding values for .t3-mainbody .t3-content .main-content-inner to fix a issue with module position. it’s not the correct way because it’s change the components layout for other pages!
- November 2014
April 27, 2015 at 2:44 am #568349I removed the screenshot include my posted in #22
About the problem on your site maybe you need to hire a dev help you out this because I have been helping you to fix but you always changed my fixes, I don’t know what did you expect on that
- November 2014
April 27, 2015 at 2:44 am #733445I removed the screenshot include my posted in #22
- October 2013
April 28, 2015 at 1:59 pm #568686<em>@Ninja Lead 470445 wrote:</em><blockquote>I removed the screenshot include my posted in #22
About the problem on your site maybe you need to hire a dev help you out this because I have been helping you to fix but you always changed my fixes, I don’t know what did you expect on that</blockquote>
yes i have removed youir fixes because your fixes produced new style issues with otherr component pages! you did not double checked this..if you change padding for .t3-mainbody .t3-content .main-content-inner then it will change also other parts of my site! >:(please assign a other moderator to my issue.
- November 2014
April 29, 2015 at 3:12 am #568750I added “reisefragen” css style into reisefragen page with css style
.reisefragen .t3-mainbody .t3-content .main-content-inner {
}.reisefragen .t3-module.module-yellowabovecomponent .module-ct .custom-yellowabovecomponent {
padding: 10px 15px;
}Now, you can enable Frontpage module and see it’s working only reisefragen page
- November 2014
April 29, 2015 at 3:12 am #733843I added “reisefragen” css style into reisefragen page with css style
padding: 10px 15px;
AuthorPostsThis topic contains 34 replies, has 2 voices, and was last updated by Ninja Lead 9 years, 7 months ago.
