  • tuyenbebi Friend
    #200047
    Hi everyone,
    I’ve got a problem with the module position aside 1, 2 and 3. You can check my link to understand.
    I’ve no idea how to drag it to the top. They are always at the bottom of the screen.
    Link: http://bebishop.vn/index.php/tuvan/2013-03-19-17-41-02/hoctap-cungbe/105-h-c-t-p/2011-d-y-teen-kheo-d-l-i-d-tranh-sa-nga
    ID and password: no required
    Thank you very much!
    swissa Friend
    #543646
    Not sure you’ll get much of a response as you posted as a non-member with a member only template but it responds as it was designed.
    Suggest you repost under the user name that bought and paid for the rights to use JA Wall.
This topic contains 2 replies, has 2 voices, and was last updated by  swissa 10 years, 4 months ago.
