  • toloekka Friend
    #152305
    Hi.
    I would like to have an extension (Rokslideshow) in the main area (body) under Breadcrumbs, but I cant find that module position. Do I have to make my own module position?
    Tom Løkka:)
    Dear Tom!
    it’s the top position, you put the module in there
    GOod luck
    Arvind Chauhan Moderator
    #349235
    Hi Tom,
    You can refer the module position guide :
    You can always find the modules position in the userguide threads (sticky) in respective templates forums.
    For kyanite II userguide thread check this >> http://www.joomlart.com/forums/topic/ja-kyanite-template-installation-and-configuration/
    Arvind
    toloekka Friend
    #349331
    If I use top position, I got Rokslide above Breadcrumbs and Left position. I will have Rokslide in the main area, under Breadcrumbs and to the right of the Left position.
    I have now made my own position (mypositiion) and loaded the Rokslide in an article. So now I got the Rokslide where I will have it.
    Maybe this is the only way to do it?
    Tom Løkka
    Dear Tom!
    Pls try following to the wiki, http://wiki.joomlart.com/wiki/JA_Template_Framework/Guides you ‘ll create a position for putting the module
    GOodluck
This topic contains 5 replies, has 3 voices, and was last updated by  Saguaros 14 years, 6 months ago.
