  • k2joom Friend
    #151469
    When Pyro was first released and Installed, running a ?tp=2 revealed and displayed all the correct module positions. I had to do it that way as there was no docs on module positions available.
    There is now a module position image now, but it does not display the same modules positions that are actually available in the template. I am left thinking, is the screenshot wrong or have module positions been left in the template.
    Anyway, due to the installer error, the file has been upgraded and now the module positions are not displayed correctly.
    Check screenshots here
    and here.
    This is from the very latest release, I have no idea what version we are on, as the version numbers have not been updated which is a bit slack.
    In addition the JA Extension Manager is reporting that there is no update available for Pyro, possibly because of the above?
    This is purely feedback guys, as this is my first experience with JA and I have to be honest, I am a little disappointed with my experience so far. Specifically, how can a template be released and it not be tested. Installer error is kind a of a fundamental thing that all users need.
    Simon
    K2 Support
    K2Joom
    prakash Friend
    #345345
    tp does reveal the module positions correctly. If you see on JA site
    http://templates.joomlart.com/ja_pyro/?tp=1
    it will clearly show all the module positions.
    hence, you could try to delete the template and reinstalling again…maybe the files did not upload correctly or some file may have gone corrupt. hence its suggested to re download and upload the template file again.
    k2joom Friend
    #345421
    OK, so which version is the demo running, as I guess the template that the demo is running has not been updated following the changes to the download files, which is what I already said.
    The original worked, but the subsequent 2 updates do not.
    k2joom Friend
    #345423
    Maybe its me, but I just checked that link in FF and Flock and the modules do not render correctly.
    Again, here is another screenshot, this time taken from you demo page
    Wheres User14 and 15?
    Why is there a huge gap after col-mas2 and the bottom section?
    Why does the bottom border image not always meet up with the left and right borders.
    uniquebiz Friend
    #345438
    k2joom;180848Maybe its me, but I just checked that link in FF and Flock and the modules do not render correctly.
    Dunno about the user 14 & 15 but the huge gap is just the allowed field for the comment showing, found by hovering over the ‘e.’ that shows in the white space the word comment shows. Maybe tp=1 only shows the positions actually active and used?
    Cheers Shannon
    congtq Friend
    #346187
    Dear k2joom and uniquebiz
    JA Pyro is using T3 JA Framework and was defined some positions (user11 -> user16) in templatesja_pyrolayoutsblockscontent-botsl.php. However, in the JA Pyro demo site, they didn’t use yet. So when running with ?tp=1 they are empty.
    You can add some modules with these positions (user11 -> user16) to see result.
    Thanks.
This topic contains 6 replies, has 4 voices, and was last updated by  congtq 14 years, 5 months ago.
