  • tennis2table Friend
    #730881
    How can I insert a new module in the position-herder-top position which would be below the drop down menu Site http://www.tennis2table.com across the width?
    Thank you in advance for your help
    Exemple (image)
    Adam M Moderator
    #749172
    Hi @tennis2table,
    Try open file templatesja_elasticablocksheader.php then look for this code :
    <ul class="no-display">
    <li><a href="<?php echo $this->getCurrentURL();?>#ja-content" title="<?php echo JText::_("SKIP_TO_CONTENT");?>"><?php echo JText::_("SKIP_TO_CONTENT");?></a></li>
    </ul>
    add new position above it as below :
    <?php if($this->countModules('header-top')) : ?>
    <div id="header-top" style="clear: both;">
    <jdoc:include type="modules" name="header-top" />
    </div>
    <?php endif; ?>
    </ul>
    Next, open file templatesja_elasticatemplateDetails.xml and look for this code :
    <position>top-panel</position>
    add new position right below it :
    <position>header-top</position>
    tennis2table Friend
    #749187
    Thank you very mutch
This topic contains 3 replies, has 2 voices, and was last updated by  tennis2table 9 years, 2 months ago.
