  • Usahawan Terbilang Friend
    #974604
    Hello admin, i have a problem with my ja social 2 template, the sidebar-2 module appear in false position, please refer attached picture.
    please advise, how to overcome this problem.
    live site : http://abangyasir.com/pemasaran-internet
    1. ja-social2-module-position-problem
    Hi Usahawan Terbilang,
    This issue often due to the wrong tags usage which caused messed up HTML mockup. You can try to disable K2 items in this page one by one to figure out which item caused issue. Then check the output content of that item to see what’s wrong there.
    #975385
    i have deleted all tags from the article, but still same problem
    i’ve disable all other article and only left 1 article without using any tags.
    please refer this page http://abangyasir.com/pemasaran-internet (module sidebar-2 position problem)
    some other page did not produce this problem, such as this page:
    http://abangyasir.com/perniagaan-internet (the module sidebar-2 working fine)
    any idea ?
    As I can see that in both of these pages, the sidebar-2 is showing properly now, is that solved?
This topic contains 3 replies, has 2 voices, and was last updated by  Saguaros 8 years, 2 months ago.
