  • cardin Friend
    #177450
    How can I have a Module Position on the right side of the Left Column but above Right column? Please see the attached image for better understanding. I want a module position like ‘User 1’ shown on the image. Thanks for any help.
    1. Module_Map
    #454662
    Hi cardin,
    Is your site running j1.5 or j2.5 ? Is it ja purity ii template ?
    cardin Friend
    #454973
    I am using J2.5.
    Anyways, I found the solution. It was simple actually. I activated and used the <inset2> module position instead of the right column and use <content-mass-top> module position.
    Thanks, anyways.
This topic contains 3 replies, has 2 voices, and was last updated by  cardin 12 years, 7 months ago.
