  • jmesq32 Friend
    #928036
    Hi working with this template at the beginning, and when I try to configure the Module Position of the JA Slideshow Lite extension the position Slideshow it is not there.
    Help please because I am starting a new site follow the documentation and this is not a good start ……
    Thanks in advance Jorge Mesquita
    timtecsa Friend
    #928039
    Hi Jorge,
    Did you try keying in the word slideshow in the position box ? Usually the ‘hidden’ positions reveal themselves this way.
    Tim
    1. slideshow
    Link you posted is a Purity III based website you opened this topic in ja-Nuevo Forum anyway to add a position to the template edit this file /templates/your_template/templateDetails.xml and add ( if not already there ) the slideshow position into the "positions" section.
            <position>article-bottom</position>
            <position>article-sidebar</position>
            <position>banner-top</position>
            <position>head-social</position>
            <position>leading-sidebar</position>
            <position>section</position>
                    <position>slideshow</position>
        </positions>
    jmesq32 Friend
    #928043
    Thanks pavit for your info , I know that the Purity III is the default template , because I have the site online for my costumer , just want to try the Nuevo template and as I started I have this issue, but ok I will see if I can done this working. Thanks a lot
    jmesq32 Friend
    #928044
    Thanks I will try that.
    jmesq32 Friend
    #928070
    <pre style="" class="prettyprint linenums:1 prettyprinted">
    1. <span class="pln"> <span class="tag"><span class="pln">article-bottom<span class="tag">
    2. <span class="pln"> <span class="tag"><span class="pln">article-sidebar<span class="tag">
    3. <span class="pln"> <span class="tag"><span class="pln">banner-top<span class="tag">
    4. <span class="pln"> <span class="tag"><span class="pln">head-social<span class="tag">
    5. <span class="pln"> <span class="tag"><span class="pln">leading-sidebar<span class="tag">
    6. <span class="pln"> <span class="tag"><span class="pln">section<span class="tag">
    7. <span class="pln"> <span class="tag"><span class="pln">slideshow<span class="tag">
    8. <span class="pln"> <span class="tag">
    Hi @jmesq32
    Could you explain in details what your post above means ?
    If you are still having problems with it you can share as private reply a temp super user account for the website where problem is and i will have a look at it.
    jmesq32 Friend
    #928390
    Hi pavit ,,,,,, problem solved I have just keying in the word slideshow in the position box and it worked
    Many thanks
    Jorge Mesquita
    jmesq32 Friend
    #928391
    Hi timtecsa , it works thanks for your help
    Jorge Mesquita
This topic contains 8 replies, has 3 voices, and was last updated by  jmesq32 8 years, 7 months ago.
