  • houghtonpw Friend
    #131815
    What are the menu positions supposed to be set at for the
    a) Product Scroller
    b) Image JASlide Show
    Paul
    #264007
    Hi houghtonpw !
    – Postion for Product Scroller is vm-lp
    – Position for Image JASlide Show is slideshow
    you can get position module by go to : http://template15.joomlart.com/ja_mesolite/?tp=1
    houghtonpw Friend
    #264038
    How do I make the position for module SLIDE (I dont have it on my list of positions)
    Joomla 1.5.5
    #264260
    Hi houghtonpw !
    you make position for modile in templateDetails.xml file , you open templateDetails.xml file in templates/ja_mesolite folderm find following code section at about line 334 :
    <positions>
    <position>hornav</position>
    <position>breadcrumbs</position>
    <position>banner</position>
    <position>left</position>
    <position>right</position>
    <position>top</position>
    <position>user1</position>
    <position>user2</position>
    <position>user3</position>
    <position>user4</position>
    <position>user5</position>
    <position>footer</position>
    <position>syndicate</position>
    <position>debug</position>
    </positions>
    you can add new postion in that.
    sorry for missing , we will update it soom.
This topic contains 4 replies, has 2 voices, and was last updated by  Sherlock 16 years, 4 months ago.
