  • gribblej Friend
    #184897
    The module positions appear briefly but then revert to showing a bunch of “object arguments.” “View module positions” is enabled in the tttemplate options; so I don’t understand why this would happen.
    Thanks,
    -Jim Gribble
    Did you have the last T3 Framework plugin installed ?
    Download and install ( if you haven’t done already ) the ja_extension manager component and update all Joomlart plugins and modules
    gribblej Friend
    #483213
    Yes, the plugin already was installed and enabled. Now it’s working. I installed the T3 plugin that came with the template package. Maybe that did it.
    Thanx,
    -JG
    Check also your home page now it’s working too
This topic contains 4 replies, has 2 voices, and was last updated by  pavit 11 years, 10 months ago.
