  • djtaylor Friend
    #172225
    Hi i have a problem with a module position as you can see on the pic
    i would like to make it so its not showing up as i do not need to use this
    i have tried to see if there are any module using the unknown position
    but i dont think there is any using it or i cannot locate .
    could any one give me help with this thanks very much.
    website link http://thatmixtape.com
    1. preview
    You cannot see it because is the content main position
    If you don’t need it you can disable in the Profile setting tab create a new profile named nomain set “Hide main content” to Yes
    after done that assign the profile only at the home in page assignments
    djtaylor Friend
    #431570
    ok thanks, also if i do want to put a module there how comes i can not find the module position content is it content-main?
    because when i click publish it never shows up, or how do i put content to show up as its a bit hard as i did not use the the quickstart?
    The main content is the core of the template, it’s not listed in menu position, but you can put the content choosing the menu type from your main menu Home item example if you set as item type of your Home “Featured Articles” then all your articles marked as Featured will be shown in that position.
    djtaylor Friend
    #432004
    Hi i have messed around with this and i would like to get rid of the main content just on the homepage as when i hide the main content on the profiles it takes it off on all pages i would like it just taken of home page but shown on every other page for example news page i would like it to show?
    You must create a new profile with Hide main content block set to Yes and assign this new profile at the home page only
    djtaylor Friend
    #432008
    thanks i have created a new profile with hide main content
    but how do i assign the new profile to the home page
    djtaylor Friend
    #432011
    i have worked it out but its annoying that there just a blank part of the template there it would be nice if i could replace the blank by puting modules there
    You can use this link to see all your positions available for modules
    http://thatmixtape.com/?tp=1
    infosource Friend
    #432630
    I am using JA Ironics template 1.7 , in that template “right-mass-bottom” position is not there, but in back end we can see “right-mass-bottom” position… and i need “right-mass-top” position . it should be opposite of “left-mass-top” position…
    If we see using ‘?tp=1’
    i want replace “content-mass-bottom” into “right-mass-bottom” position…
    can u help me?
    1. right-mass-top
This topic contains 10 replies, has 3 voices, and was last updated by  infosource 12 years, 11 months ago.
