January 17, 2017 at 3:28 am #1002973
Hello Sanguaros
I have a big problem with the modules I had everything to place yesterday and I arrived on my site after noon and the modules in the pages are all packed on the side and I can not find the why and how to arrange his and It has a page that modules works. My site is under maintenance.
Thank you.
January 17, 2017 at 9:07 am #1003063Hi,
It still looks good at my end, did you get it solved?
January 17, 2017 at 9:53 am #1003099Hi Saguaros
No the problem is not settled and its still the same all the trailer is tamp on the side?
Saguaros ModeratorSaguaros
January 17, 2017 at 10:05 am #1003106Could you provide the URL of page where I can see the issue?
January 17, 2017 at 10:10 am #1003110All pages I have module problem
example: http://www.lanauweb.info/nord/index.php/actualite
January 17, 2017 at 10:37 am #1003116Hi,
I got your point and the problem comes from the settings only.
The ‘Sports’ category on your site contains only 1 article while in ACM Module [Magazine – Sport] – Featured news in news-sport position, you set to show more than 1 and caused the issue.
I tried to duplicate some article into ‘Sports’ category and you can see that it displays correctly now: http://www.lanauweb.info/nord/index.php/sports
January 17, 2017 at 11:19 am #1003120I am redoing the modules with the same configuration that you did for the modules of the sports and I have a problem with the page politics
January 18, 2017 at 2:15 am #1003297I checked the politics page on your site and saw that it’s working fine now, is that ok now?
January 18, 2017 at 5:26 am #1003343Yes his walk I arranged everything. I would have a question how I create new possition I have two new section and I have to create the possition new -… and after I insert the modules I want dedan. My I do not understand how creates the possition.
January 18, 2017 at 6:38 am #1003352You can follow this docs for how to work with position and layout in T3 framework: http://www.t3-framework.org/documentation/bs3-layout-system#add-position
AuthorPostsViewing 10 posts - 1 through 10 (of 10 total)This topic contains 9 replies, has 2 voices, and was last updated by Saguaros 7 years, 8 months ago.
