  • antoniu1 Friend
    #116865
    Hi!
    First of all, great templates!
    I have installed Hadar and experience a huge placement problem in Explorer: ALL ‘user4’ and ‘left’ modules are always placed on the LEFT side, on top of ‘bottom’.
    This is not happening in Firefox, there it all works perfectly.
    How can I correct this?
    Thanks,
    Tom
    Hung Dinh Friend
    #209772
    Hi Tom,
    Could you please post your URL so that we can have a look and find the problem?
    antoniu1 Friend
    #209825
    Hi Hung,
    I have just now changed the template back to Hadar to create the problem again, but it seems solved. Don’t ask me how. I have changed some global settings, that might have corrected it.
    Thank you for your great response in any case!
    Tom
    Hung Dinh Friend
    #209828
    Glad that it has worked work, feel free to post if you need any help 😉
This topic contains 4 replies, has 2 voices, and was last updated by  Hung Dinh 18 years, 5 months ago.
