May 4, 2008 at 3:50 pm #128208
I’m new to this so please bear with me. Here are my questions:
1) I have followed the help instructions and managed to install the template itself. Step 2 says to install the modules. Unfortunately, I do not have a ZIP file containing these modules. Am I missing something here? The only ZIP file in the installation file that I downloaded contained the Newsflash module. I am assuming that there are others, however! Please help!
2) I switched from the Default template to the new Joomlart Template (JA Mageia). However, when I am in the Control Panel looking through Content, none of the Content matches the new template. It still reflects the old one. This doesn’t make any sense to me. Did I do something wrong? How can I change this?
3) I wanted to change both the logo and the header image. After excessive searching I found the image files in the directory that needed to be replaced (NOT via the Control Panel — shouldn’t this be doable via the Control Panel?) Anyways, when I attempted to upload the new logo, I received an error stating that my directory isn’t writable. So, I attempted to make the directory writable but keep receiving error messages. Therefore I am unable to change these images.
I realize I am asking many questions, but I’m totally confused and any help that can be offered is greatly appreciated!!!
Thank you.
MicheleSherlock FriendSherlock
- 2478 times in 2162 posts
May 5, 2008 at 1:31 am #247749Hi five49x2 !
1, JA Megeia package for 1.0 only includes template package and newflash module package , What module do you want to use ?
2, I have viewed your site ,it’s working with JA Megeia template , Did you change it ?
3, You must change permission for templates folder , set permission for it to “777”May 5, 2008 at 1:48 am #247751Hi hainn84,
Thank you for your reply!
There are no modules that I would like to use specifically; but since the installation instructions said to install the module file, I got confused. As long as it looks like its working, I guess things are okay.
Regarding changing the permissions on the templates folder: in fact, the templates folder has the permissions set to 777. However, I am still unable to change the logo image. I don’t know what to do!
Please advise! Thank you much.
Michele
This topic contains 4 replies, has 2 voices, and was last updated by Sherlock 16 years, 4 months ago.
