  • renejdm Friend
    #180410
    I have run into a strange problem where any module suffix (i.e., pink or dark) that is entered is ignored. Go here to see the problem:
    http://www.petdietdesigner.net/login
    The module on the right should be pink. It is white. I also tried “dark”, but that does not work either.
    Any ideas?
    Rene
    tfosnom Friend
    #465974
    Hi Rene
    Just a quick idea, when you entered the suffix you did enter it with a leading space? In a rush, It’s caught me out before.
    Cheers Shannon
    renejdm Friend
    #465977
    Hi Shannon,
    You’re a life saver! That indeed solved the problem.
    Thanks,
    Rene
    P.S. It is a mystery to me why it is this way. Perhaps the developers could create a helper function/method that would insert a blank space.
This topic contains 3 replies, has 2 voices, and was last updated by  renejdm 12 years, 4 months ago.
