  • gverheij Friend
    #175411
    Hi, I use the module foot-left of JA_Nex, although I renamed the modules to user16 .. user20, below, see my modified nex-layout-code:
    <block name="botsl" type="spotlight" wrap-inner="1" >user5,user6,user7,user8</block>
    <block name="botsl1" type="spotlight" >content-bottom1</block>
    <block name="botsl0" type="spotlight" main-inner="1" wrap-inner="1">menu-footer</block>
    <block name="botsl2" type="spotlight" main-inner="1" >user16,user17,user18,user19,user20</block>
    <block name="footer" type="footer" ></block>
    </blocks>
    The module-title (enabled off course) does not show! Why is that? In foot-right, the Connect-module, the title does show as expected!
    Is there a module-suffix of some other setting I should use to get the title displayed??
    Thanks for your answer, Gerard Verheij
    khoand Friend
    #445705
    Could you give me username+password of your backend? I will check it.
    khoand Friend
    #445727
    They have title normally. But color of their title is black. So you can’t see it. They are defined in /templates/ja_nex/css/template.css
    div.ja-moduletable h3, div.moduletable h3 {
    border-bottom: 1px solid #DDD;
    color: #222;
    font-family: 'TeXGyreAdventorRegular',Helvetica,Arial,sans-serif;
    font-size: 100%;
    margin: 0;
    padding: 13px 15px;
    text-transform: uppercase;
This topic contains 3 replies, has 2 voices, and was last updated by  khoand 12 years, 9 months ago.
