May 27, 2008 at 7:14 pm #128968
Hello
For some reason I start to get this problem, when I create a new module ( user module ) I get the css script on the title ex:
<span class=”ja-contentheading”>Building Trades News</span>
the title still is getting the css style attribute but is showing the code too. Was working good before and nobody on my office touch nothing. cuold be a server update ? or any idea.
Sherlock FriendSherlock
- 2478 times in 2162 posts
May 29, 2008 at 7:33 am #251012“ja-contentheading” ?
I think that don’t have that class . It must is “contentheading” , Please send link of your site !May 29, 2008 at 6:38 pm #251078Sherlock FriendSherlock
May 30, 2008 at 2:39 am #251116Hi magicbag !
Please remove <span class=”ja-contentheading”> in module name text box on admin . If you put module name is “<span class=”ja-contentheading”>Building Trades News</span>” in admin , It will display all text in frontend !May 30, 2008 at 6:20 pm #251264Hi hainn84,
Thank you for your response.
That would be an easy fix but unfortunately, the is not the case for my problem
In the backend the Module Details Title is only ‘Building Trades News’ but, as you see in the front-end, it displays: <span class=”ja-contentheading”>Building Trades News</span>
This is only happening with modules that I create using ‘New” under Modules>Site Modules>New. All the other modules are displaying the header correctly.
They were all working correctly two weeks ago but for some reason only the modules created with the ‘New’ button started displaying the span code. There have been no changes to the system from our end.
For a temporary fix, I have turned off the headings.
Any other suggestions would be greatly appreciated.
Menalto FriendMenalto
- May 2007
- 531 times in 361 posts
May 30, 2008 at 6:34 pm #251267Which joomla version are you using?
Any updates you have done with joomla or server lately?May 30, 2008 at 8:25 pm #251277Joomla1.0.15, but we find the problem start when we please content in the body message, if we leave blank just the title is work correctly.
May 31, 2008 at 1:26 am #251311HI magicbag !
Please send admin information via pm . I will check it for you !Sherlock FriendSherlock
June 4, 2008 at 2:02 am #251800Hi magicbag !
Please check again : http://www.buildingtradesnews.com/ , It is good now
My way for solved it :
1.Login to admin
2. Select Building Trades News Module then disable mambot for thia module. View image attachment for detail . -
This topic contains 10 replies, has 3 voices, and was last updated by magicbag 16 years, 7 months ago.
