I have been trying to get a module to span the whole page.
I created a custom module and added a background image to the template file but that did not work because the image is not responsive. Also I put an image in the module but can’t get it to be wider than the main body. I have tried modifying the css still not the results I need.
You can see what I am trying to do at dev.metroinstitute.org. Look at the image below the header. That is the background image and I have a transparent image in front of it that is in the module “custom out put.
I want the background image to be responsive or the module image to be full width.
Thanks,
Kelark
