May 9, 2012 at 9:25 pm #176894
Hi everyone, new on this board and I could use your help.
I am running Joomla 2.5.4 with the JA_Nex template and the K2 content system as well. Although I know how to position a module with content (from either Joomla or K2) on the page, for the life of me I can’t figure out how to have it show a few links and then a “Read more” button. I am trying something similar to the http://www.cnn.com site, for example the newsbox for the US category.
I have tried the default Joomla options as well as the JA plug-ins.
Any thoughts?
Thanks a million!
Saguaros ModeratorSaguaros
May 10, 2012 at 1:26 pm #452403Thanks Saguaros, the site (still work in progress) is http:http://www.enser.com/jooo. The position that I am trying is “user1”. Right now there’s the module “WEBINARS-CATALOG” which shows 5 K2 items in catalog mode. There are more, and I would like to have the “Read More” option in there. Also, is there a way to have those boxes with equal height? Thanks again, I appreciate it.
May 10, 2012 at 2:19 pm #452415Dear mozese,
Please check the url again. When I access with this link: http://www.enser.com/jooo
It’s a Page Not Found page. Please check it again.
May 11, 2012 at 6:16 pm #452654my bad typo http://www.enser.com/joo
Thanks,
May 12, 2012 at 2:39 am #452688Hi mozese,
As I can see that Readmore does show now:
About the height of these boxes, which modules do you use in these position: user1, user2, user3? In backend of these position, you can add class suffix for these modules and set an equal height for them.
May 14, 2012 at 4:51 pm #453020In between posts I was able to get it to work. I am publishing them to user1, user2 and user3. I will give the class suffix tip a try. By the way is there a guide somewhere to customizing the CSS? I would like to change the look of the “read more” link as well as the layout of the actual article (which is a K2 item). Thanks again.
May 15, 2012 at 3:04 am #453067Hi mozese,
This guide from JoomlArt Wiki may help you more about the theme. All you need to do in order to override is make changes for files/folders in templates folders. For example with K2 item, you should go to : templatesja_nexhtmlcom_k2templatesnex or nex_blog and make changes to K2 items. Let me know if you need further guidance.AuthorPostsViewing 8 posts - 1 through 8 (of 8 total)This topic contains 8 replies, has 2 voices, and was last updated by Saguaros 12 years, 8 months ago.
Module with content from articles with Read More…
