  • magiur Friend
    #146073
    How I can put the third part modules in the body of the single articles?
    You can use the JA Tab plugin to complete your idea.
    Here is the user guide of the JA Tab
    http://demo.joomlart.com/extensions15/index.php?option=com_content&view=article&id=109&Itemid=54
    magiur Friend
    #323923
    Yes, ok… but if the module is just a link? In the case I want to install a module like Smart Bookmarker… in the tabs have not a great effect. 🙂
    There is no other way?
    Thanks for help!
This topic contains 3 replies, has 2 voices, and was last updated by  magiur 15 years ago.
