  • tienhuynh_99 Friend
    #177317
    When I create a menu item for single article, I want to select a module in the required settings but no module shows up.
    Under Required Settings, components, plugins, modules and articles should be showing up but in my case it shows none, except articles. How do it get these components, plugins, modules to show? I’m sure that they’re published.
    I’m using JA nex 2.5 quickstart.
    Thank you for your help.
    #454044
    <em>@tienhuynh_99 320869 wrote:</em><blockquote>When I create a menu item for single article, I want to select a module in the required settings but no module shows up.
    Thank you for your help.</blockquote>
    Hi tienhuynh,
    can you pm me your url as well as the admin account for taking a look at the problem ?
This topic contains 2 replies, has 2 voices, and was last updated by  Sherlock 12 years, 7 months ago.
