  • sdbeerpong Friend
    #134364
    If you have a page you load from a link that is a menu item external link, modules will only display if you select “all” from the modules menu items in paramters.
    Example
    Menu item type – external link
    url example – index.php?option=com_comprofiler&task=usersList
    On Click, Open in – Parent window with browser navigation
    Modules will not load, except only if you have them set to “all” on Menu assignments
    If you have “Select Menu Item(s) from the List ” radio button check and every menu item highlighted the modules will not load. Is there a fix available for this?
    joomla 1.5
    #275134
    Can you please send via PM an admin account of your website so that I could look into the issue.
This topic contains 2 replies, has 2 voices, and was last updated by  Sherlock 16 years, 2 months ago.
