June 11, 2016 at 2:37 pm #939638Hi
Could you share your website url ? so we can see what is happening ?
midhat Friendmidhat
- January 2010
- 12 times in 1 posts
June 11, 2016 at 3:03 pm #939642Sorry, I thought I’d share
http://becart.ba/en/pavit Moderatorpavit
June 12, 2016 at 10:39 am #939775Hi there
For what i can see you applied a lot of changes on your custom.css file , you can try to disable it for now and see what happens , in the meanwhile if you can also share as private reply a temp super user acount to your backend i will have a look at your modules settings and answer in a better way.
midhat Friendmidhat
- January 2010
June 12, 2016 at 10:46 am #939776This reply has been marked as private.pavit Moderatorpavit
June 12, 2016 at 5:20 pm #939837Hi
Backend account doesn’t works
check it better
midhat Friendmidhat
- January 2010
June 12, 2016 at 6:13 pm #939843This reply has been marked as private.pavit Moderatorpavit
June 13, 2016 at 6:03 am #939947Hi
You should first update your T3 plugin to latest version released, then you should test your website disabling one at once all your 3rd party extensions like falang and test website again , i looked at all your files and spent some time on it and i haven’t found any difference between your website and quickstart installation on my local .
So it is not a template issue for me.
midhat Friendmidhat
- January 2010
June 13, 2016 at 1:05 pm #940096My problems are solved
- I replaced the mysql table _template_styles with a new table (from fresh installation) and a problem with the module Our Services is resolved
- I deleted directory "local" from my ja_decor template (do not know how they appeared there) and the problem with the search module is solved
Thanks for your time
Regards,
MidhatAuthorPostsViewing 8 posts - 1 through 8 (of 8 total)This topic contains 8 replies, has 2 voices, and was last updated by midhat 8 years, 6 months ago.
The topic ‘Modules problem’ is closed to new replies.
Modules problem
