  • b2control Friend
    #128784
    How can I move the modulespostions left & right at the body positions. I am really a rookie when it comes with codes.
    I have attached a example print
    1. ja_galena_user_guide_edit
    samx Friend
    #250808
    I want to do that for my site too, plz help
    samx Friend
    #250946
    umm….so how do you get support around here? post in the forum and hope that some one replies before ur membership expires? 😀
    just joking… but seriously I really want to know if it’s possible to switch the modual position on this template.
    thanx
    EDIT: OK got it
    To change it modify the template.css starting line 574
    #ja-content {
    clear: both;
    display: block;
    float: right;
    width: 52%;
    to:
    #ja-content {
    clear: both;
    display: block;
    float: left;
    width: 52%;
    again I should of tried to do this earlier, thanx to the great style ja codes, it’s very easy to modify.
    b2control Friend
    #251088
    Yes.. Thanks for the post.
    At the joomla 1.0 template version it is on line 1139.
    Kind regards
    Bruce
This topic contains 4 replies, has 2 voices, and was last updated by  b2control 16 years, 7 months ago.
