  • komang Friend
    #127255
    I have the problem for Joomla 1.5.2 when publishing MooMenu or publish Transmenu on IE 7.
    There were error script and bug showup on left bottom.
    line: 182
    Car: 35
    Error: “MooSlide Menu” is underfined
    Code: 0
    http://www.mysite.com
    please need help, how to solve this issue ?
    lotushost Friend
    #244561
    yea I have the same problem….. I’m not sure myself
    except my error is on line 112, but the same exact one
    #244685
    Hi Komang and lotushost !
    I have tried ja_larix in joomla1.5.2 and have the same bug in trans menu ( moo menu run well ) . I have fixed it . You can try this way :
    – download attachment file and extract.
    – copy and overwrite Transmenu.class.php file to templatesja_larixja_menus folder.
    I think JA will fix it in version for joomla1.5.2 🙂
    komang Friend
    #244719
    Hi, thanks very much for your file.
    I was tried, but its still no work,
    script error with “OBJECT REQUIRED”
    any idea ?
    thanks
    komang
    #244817
    Hi komang !
    do You use trans menu ? you can send imformation of your site via pm , I will fix for you !
    komang Friend
    #244830
    here is for my site http://www.balipublisher.com
    the moomenu is working But with Error/Bug show up on IE,
    and transmenu 100% cannot work, so I donot active it for online
    please check it if there are somethink wrong.
    and where is the Moderator for this Forum? I need the solution for this issue.
    Thanks so much
    Komang
    katrina Friend
    #263812
    Hi there i am to getting an error with the Moo Menu:
    mooSlideMenu is not defined
    Window.onDomReady(function() {new mooSlideMenu($(‘ja-cssmenu’), {anim:’slide…
    URL is http://www.easydairy.com.au
    Does anyne know a fix? I am running joomla 1.5
    nachtegaalh Friend
    #265693
    Whe recieve this error after installing ideal payment on our site. It’s related to JA_Larix if we select an other template all goes well.
    This are the errors we recieve
    Fatal error: Call to undefined function ampreplace() in D:vhostasokashop.euhttpdocstemplatesja_larixja_menusBase.class.php on line 98
    Fatal error: Class ‘mosParameters’ not found in D:vhostasokashop.euhttpdocstemplatesAsokashopja_menusBase.class.php on line 29
    we are using joomla 1.5.6 with vm 1.1.2.
    It seems that the menu’s are not 100% joomla 1.5 code some scipting code is stil joomla 1.0
    Who can help me with this as i am not a programmer myself.
    Henk
    gaylepetrie Friend
    #271745
    ive got the same problem. im using a joomlart template JA_Larix with VM1.1.2 and Joomla 1.5.6 and i receive a mooSlideMenu is not defined error
    any ideas anyone on how to fix this?
This topic contains 9 replies, has 6 voices, and was last updated by  gaylepetrie 16 years, 3 months ago.
