  • whouse Friend
    #123083
    What I am experiencing is the major difference in the way that IE and Firefox processes the CSS of this (and others I’m sure) template. What is happening is this: IE uses the link colors for the main navigation in the left column and I want the nav menu and the links to be two different colors. :(( It shows the way I want in FF but IE is really about to kill me and I can’t figure out how to fix it.
    I would really appreciate some knowledgeable help with the CSS.
    Please, please!
    Thanks!
    Michael Casha Friend
    #230639
    live url ?
    whouse Friend
    #230641
    Don’t spank me but it’s on a testing domain that isn’t registered. The url is junkinthetrunk.info and if you view the site using both FF and IE, you will see the differences.
    Thanks for looking.
    whouse Friend
    #230796
    C’mon guys! Isn’t there anyone around here that can help me with this? I’m drowning here! Please?
This topic contains 4 replies, has 2 voices, and was last updated by  whouse 17 years, 3 months ago.
