  • max_santiago Friend
    #206309
    Hallo Joomla digital friends,
    the questione of day is ‘at moment doesn’t run over-mouse option to admnistrate modules from frontend’.
    I pushed button on global-settings but nothing!
    What is the probable problem?! (in past days it runs ok).
    @pavit
    La domanda del giorno e’ ‘in questo momento non mi funziona piu’ la comoda opzione di ‘mouse-over’ dal frontend per gestire i moduli.
    Ho provato a selezionare/deselezionare dall’apposito cursore in ‘impostazione sito’, ma nisba!
    Grazie! 🙂
    M.
    Il sito e’ ora correttamente online > http://www.konsumer.it
    Adam M Moderator
    #570575
    Hi @max_santiago,
    May I know your site url and temporary admin account via private reply so I can have a look at the problem ?
    Adam M Moderator
    #573164
    Hi @max_santiago,
    I have just tested this matter again and it works fine with latest version, please update your template / T3 framework via JA Extension Manager and recheck.
This topic contains 3 replies, has 2 voices, and was last updated by  Adam M 9 years, 6 months ago.
