bohemiadesign Friend
bohemiadesign
- March 2010
October 19, 2015 at 10:25 am #705789HI,
I realise this might be a bit of a stretch – but is it possible to customise the menu be on-top of the clouds on the first ?page? ? similar to this site http://graphicmedia.com.au/?
On the other ?pages? I would like the menu to be at the top of the page ? the way the jaonepage is.I hope it make sense.
JhTomC ModeratorTomC
- October 2014
- 3155 times in 2495 posts
October 19, 2015 at 4:38 pm #705928For visual reference, might you be able to throw together a screenshot mock up of what it is you’re wanting to accomplish?
TomC ModeratorTomC
- October 2014
October 19, 2015 at 4:38 pm #752194For visual reference, might you be able to throw together a screenshot mock up of what it is you’re wanting to accomplish?
bohemiadesign Friendbohemiadesign
- March 2010
October 19, 2015 at 8:55 pm #705953Thanks for getting back to me.
I would like the menu be as shown in attached image when first module is shown.
When a user clicks on another menu item the menu goes back up to the top – similar to how the example link is.Thanks
jhbohemiadesign Friendbohemiadesign
- March 2010
October 19, 2015 at 8:55 pm #752219Thanks for getting back to me.
jhTomC ModeratorTomC
- October 2014
October 19, 2015 at 9:25 pm #705956Hmmmm …. While I’m sure something like that can be done, I myself am not entirely certain the best way to go about it. It could be a layering type of method … but that might mess with mobile views for your site.
While this may be beyond the scope of general Technical Support, I am, nevertheless, going to put this out to my fellow Support Team Members for their thoughts and/or ideas.
TomC ModeratorTomC
- October 2014
October 19, 2015 at 9:25 pm #752222Hmmmm …. While I’m sure something like that can be done, I myself am not entirely certain the best way to go about it. It could be a layering type of method … but that might mess with mobile views for your site.
- March 2010
October 19, 2015 at 9:28 pm #705957I Appreciate that but I realise this is probably beyond support for the template.
Cheers,
Jbohemiadesign Friendbohemiadesign
- March 2010
October 19, 2015 at 9:28 pm #752223I Appreciate that but I realise this is probably beyond support for the template.
Cheers,
JTomC ModeratorTomC
- October 2014
October 19, 2015 at 10:00 pm #705958<em>@bohemiadesign 498358 wrote:</em><blockquote>I Appreciate that but I realise this is probably beyond support for the template.
Cheers,
J</blockquote>Well, you can certainly try to post your project up on JOOMLANCERS or some other freelance site.
TomC ModeratorTomC
- October 2014
October 19, 2015 at 10:00 pm #752224<em>@bohemiadesign 498358 wrote:</em><blockquote>I Appreciate that but I realise this is probably beyond support for the template.
Cheers,
- March 2010
October 20, 2015 at 12:19 pm #706077Hi,
Thanks I will sign-up with them.Another idea is if I could hide the top header (logo +menu) when the home module (module with clouds) is shown. Then I can add the menu links to the custom html module where the clouds are.
JHbohemiadesign Friendbohemiadesign
- March 2010
October 20, 2015 at 12:19 pm #752294Hi,
JHTomC ModeratorTomC
- October 2014
October 20, 2015 at 4:01 pm #706092<em>@bohemiadesign 498472 wrote:</em><blockquote>Hi,
JH</blockquote>Certainly something you could experiment with. I’m of the opinion that virtually anything can be accomplished – one way or another – with a bit of trial-and-error (and a whole lot of patience). 🙂
TomC ModeratorTomC
- October 2014
October 20, 2015 at 4:01 pm #752309<em>@bohemiadesign 498472 wrote:</em><blockquote>Hi,
This topic contains 15 replies, has 2 voices, and was last updated by TomC 9 years ago.
