willer Friend
willer
- 10 times in 1 posts
September 17, 2016 at 9:38 pm #968871Good evening, I would like to know if you can move the home-1 position. I would like to move it above the navhelper position. Currently however, it lies below. I enclose screenshoot explanatory.
Thank you
Saguaros ModeratorSaguaros
September 21, 2016 at 1:24 am #969601Hi
The ‘home-1’ position included in the mainbody block. There are 2 options:
- Create a new block which will load ‘home-1’ position, then load this block into the layout you’re using.
- Add the navhelper position into the mainbody block like the way ‘home-1’ position is added.
For more info about block in T3 framework, check out this documentation: http://www.t3-framework.org/documentation/bs3-layout-system#add-block
AuthorPostsViewing 2 posts - 1 through 2 (of 2 total)This topic contains 1 reply, has 2 voices, and was last updated by Saguaros 8 years, 2 months ago.
