  • munders Friend
    #171192
    Hi there
    How do i move the default left column to the right side please?
    This is the column that includes the default demo modules such as My Cart and Categories.
    bhall2001 Friend
    #426990
    Pretty simple…
    Log in to your admin. Next find each module that is in the left side (one at a time) and open it up. You’ll see a pop-up in the “Details” section on the left labeled “Position:” Click and hold on the pop-up menu to list the positions available. If you scroll down in this list you will see that one of the options is “right”.
    Select “right” then click the save button. Do this for each of the modules in the left column and you’ll move them to the right column.
    QED 🙂
    Bob
    munders Friend
    #426996
    Thanks Bob
This topic contains 3 replies, has 2 voices, and was last updated by  munders 13 years ago.
