  • itshugh Friend
    #202290
    I have created a multilingual site – 3 different languages (English German and Swedish). 4 Main menus (one for “all” languages), and 4 different “home” pages etc. However, it still doesnt work! I have followed all the instructions, but obviously have missed something.
    Can someone help me?
    itshugh Friend
    #553731
    Just realised I havent described my problem! When I open the start page – its the English (not the “All language”) menu which comes. The only language I can chose in the languageswitcher module is English! Swedish and German are not visible. I use a Swedish web browser
    Adam M Moderator
    #553760
    Hi @itshugh,
    1. For more detail about how to create multilingual website, you can take a look here.
    2. We do provide a free component named JA Multilingual Component to help you easily create multilingual site and you can see its documentation here.
    itshugh Friend
    #553766
    Hi Adam,
    I have read the instructions (and followed them!) I have also installed the Multilingual component. However something is wrong with my configuration.
    I cant see it, I have went over the configuration several times now and everything seems ok. However it still is not working as it should be.
    I am sure if someone else looked at it they would see the problem straight away!
    Adam M Moderator
    #553930
    Your problem has been solved via our support ticket system so I will quote the answer here :
    <blockquote>1. The language tag: Extension >> Language Manager >> Content >> http://prntscr.com/52k7t5
    It must be the same as in the “Installed-Site” >> http://prntscr.com/52k7y0
    2. The MegaMenu for each language in template configuration
    For each language, you have to set the Menu for the style.
    For example: Language German: Extension >> Template Manager >> ja_medicare – de-DE >> http://prntscr.com/52k8bv
    Result: http://prntscr.com/52k8ek</blockquote>
This topic contains 5 replies, has 2 voices, and was last updated by  Adam M 10 years, 2 months ago.
