  • mronday Friend
    #188579
    Hi All,
    I’m using the hawk store template for a multi language website. But i’ve a few problems.
    • When website goes to page that’s not direct in menu, the menu total dissapears by one of the two languages. Example, if you search and the search results show up, the menu is gone in the dutch version of the site. When you search in the english version of the website the menu stays. (how can i fix it for the dutch version) ?
    • The same happens when you view the cart.
    Is there an option to fix this problems? My test website runs at http://networks.rondaypc.nl
    Thanks in advance,
    Mike,
    mronday Friend
    #497664
    Problem is solved,
    ovdb Friend
    #500622
    Hi Mike,
    how did you solve it?
    Same here with FR – NL – EN multilanguage website.
    Olivier
    mronday Friend
    #500748
    Hi Olivier,
    You have to make a menu for NL, FR AND EN. So Home-NL, Home-EN, Home-FR.
    Afther that you create a templatestyle Home-NL, Home-EN AND Home-FR. In these style you select frontpage layout and under the menu settings you choose the NL, EN or FR menu. (these styles do you assign to Homepage for NL, EN and FR)
    Than you create another tree menu’s for the other pages. So website-NL, website-EN and website-FR. Under menu you choose the correct menu. and you assign these to the other pages off the language.
    I hope you understand it ? Let me hear.
    Good luck
    Kind Regards,
    Mike Ronday
This topic contains 4 replies, has 2 voices, and was last updated by  mronday 11 years, 4 months ago.
