December 14, 2016 at 12:04 pm #994621
Hello Everyone, since I upgraded my website to Joomla 3.6.6 I have an issue with the multilanguage switch.
In fact when I switch from a language to another, the main menu disappears, but once I refresh the page it appears.
you can check the problem here : http://www.hotel-marrakech-semiramis.com/fr/
Thank you
- November 2014
- 3854 times in 3563 posts
December 15, 2016 at 2:52 am #994729Hi,
Kindly check these:
Go to Menu of your site and make sure that you have FR and EN menu languages
- Go to template manager and check the configuration and you have each template style for each language: EN and FR
By the way, pls renew your membership to get technical support.
December 15, 2016 at 11:28 am #994843Hi,
I did all what you said, but the problem is still here !After switching languages I need to refresh the page to see the menu appear.
- November 2014
December 16, 2016 at 1:18 am #994927Hi,
It’s very strange with the problem on your site, you can give me the admin login and FTP account and set as private reply. I will check for you
December 19, 2016 at 10:53 am #995735This reply has been marked as private.Ninja Lead ModeratorNinja Lead
- November 2014
December 20, 2016 at 1:34 am #995957Hi,
I could not access the backend of your site with the credential info above
Warning You do not have access to the Administrator section of this site.
Please help me to check this
December 20, 2016 at 9:40 am #996110Hi,
now it’s okay.
Thank youNinja Lead ModeratorNinja Lead
- November 2014
December 21, 2016 at 3:27 am #996283Hi,
It’s very strange with the problem on your site, it only loads the menu when your site reloads. You can give me the FTP account of your site via private reply. I will check the coding on your site
December 21, 2016 at 4:19 pm #996442This reply has been marked as private.Ninja Lead ModeratorNinja Lead
- November 2014
December 22, 2016 at 2:58 am #996538Hi,
The FTP account seems not work: http://prntscr.com/dmg0u7 kindly check and send me again.
Also, you should send me the super admin account of administrator panel on your site.
December 22, 2016 at 5:04 pm #996720This reply has been marked as private.Ninja Lead ModeratorNinja Lead
- November 2014
December 23, 2016 at 8:52 am #996886Hi,
The problem on your site is very strange. I disabled the SEO setting on your site: http://prntscr.com/dmyclw and the problem on your site is gone
What did you make a custom on your site?
December 23, 2016 at 2:50 pm #996961this is very strange.
I’ve just noticed that too.
I didn’t do any customization on the site… things were working normally before the update.I can’t let the URLs appear like this
- November 2014
December 26, 2016 at 8:15 am #997312Hi,
I fixed the problem on your site with the solution below
- Open templates/ja_decor/tpls/blocks/header.php file
find and change
<jdoc:include type="<?php echo $this->getParam('navigation_type', 'megamenu') ?>" name="<?php echo $this->getParam('mm_type', 'mainmenu') ?>" />
to
<jdoc:include type="<?php echo $this->getParam('navigation_type', 'megamenu') ?>" name="<?php echo "mainmenu-".$lang[0]; ?>" />
Now, the problem on your site is gone. You can check it again let me know if it helps
This topic contains 13 replies, has 2 voices, and was last updated by Ninja Lead 8 years ago.
