October 30, 2017 at 2:04 pm #1071014
HI!
I ave searching in the forum but no help about my problem
To make it easy to undesrtand , if i have a shop and it is located in 2 or 3 cities, how can i register that in k2 extra fields using the component , specially that all extra fields from JA K2 Filter must be Text Filed to be able to show, and that make it impossible to be able to choose more than one cityLuna Garden ModeratorLuna Garden
- July 2011
- 453 times in 425 posts
October 31, 2017 at 7:55 am #1071253October 31, 2017 at 9:08 am #1071275Any help please!
October 31, 2017 at 12:29 pm #1071354Ok.. I am talking about bac-kend, I can see extra fields values from the filter only if it text not any other kind
look at attached images, if i declare something else than text field then when i want to use the extra field is empty
- This reply was modified 7 years, 1 month ago by angelos33.
November 1, 2017 at 6:33 pm #1071716
Please answer me so i can go on!
- July 2011
November 2, 2017 at 2:25 am #1071765Hi,
As your capture, you use Multi-Level Fields Data, and this function doesn’t allow to set more than one value.
You can check JA K2 Filter document about Multi-Level Fields here: https://www.joomlart.com/documentation/joomla-component/ja-k2-filter#version-119
November 3, 2017 at 1:26 pm #1072147That is sad actually , specially that Multi-Level Fields Data is one of the reason that many use/buy the component for
- July 2011
November 10, 2017 at 3:44 am #1073504 -
Viewing 8 posts - 1 through 8 (of 8 total)This topic contains 7 replies, has 2 voices, and was last updated by Luna Garden 7 years, 1 month ago.
