June 22, 2007 at 10:21 pm #121009
I want to make a site which is using more than one joomlart templates.
I mean I want to use different templates for induvidual sections by using different menu system for each sections.for example;
section1 menu name : s1menu using transmenu on top and template name xenia
section2 menu name : s2menu using splitmenu on top and template : utahia
……and I’ll assing template to sections only
Is it possible?
Cause I changed menu name ‘mainmenu’ to ‘s1menu’ in code
and homepage is ok but when I click to another sections title there is an error apper (changing template)Parse error: syntax error, unexpected T_STRING in /home/zzzzxx/public_html/templates/ja_quillaja/ja_splitmenu.php on line 15
Sorry about my english I hope I could explain the situtiation
thanks
TomC ModeratorTomC
- October 2014
- 3155 times in 2495 posts
June 22, 2007 at 10:45 pm #222612This is something I have been contemplating as well – and is in direct relation to my question about whether or not one can have more than 50 module positions designated within the Joomla Administration?
I believe you can designate different templates for different sections. The trick is to make sure that there are no conflicting module positions between the templates (i.e. both templates having a “user1” module position, but different functions designated for each template. In this case, I think it is best to custom name your modules (as opposed to the generic “user1, user2, top, bottom,” etc).
For this reason, I am hoping there is a way to create/designate more than 50 positions within the Joomla Module Position Administration Panel – because then you can create your custom-named module positions – and then designate them to the appropriate template and there should not be any cross-content problems.
Hope that made sense.
TOM
June 22, 2007 at 11:23 pm #222613Thanks tcraw1010 your reply was helpfull.
I found why getting error ;
it is interesting but when I inspect the templates php code like transmenu.php
that is look below ;$japarams->set( ‘menutype’, ‘mainmenu’ );
Source of menu
//Set style for menu
$japarams->set( ‘menu_style’, ‘horizontal’ );
Value: horizontal, vertical
$japarams->set( ‘menu_direction’, ‘down’ );the unexpected T_string errors come from alone lines only //
and I fix it like
// Value: horizontal, verticaland everythings ok.
interesting because I didnt change anything in the codes
This topic contains 3 replies, has 2 voices, and was last updated by osubasi 17 years, 4 months ago.
