Viewing 15 posts - 1 through 15 (of 17 total)
  • loci Friend
    #169796
    Hello to everybody
    i try to translate my ja travel but i have some problem.I need ti have in Italian and English.
    For start i need to tell that my site is made in italian language…i mean that when i’m starting to build i didn’t think about to translate and every content is set to “language= ALL” but the text is in italian and the site DEfault language is set to ITALIAN.
    Now i follow a link
    http://wiki.joomla.it/index.php?title=Multilingua_in_un_sito_Joomla_1.6
    and create all the category, content in english… i have create the menu in english and pubblish…i have create the module for the menu….and pubblish System – Language Filter.
    So in the default home (language italian) i can not see the featured article but all the other and i can see the flag for the English language but and if i click on the response is that:
    404 – Category not found
    so anyone could help me???
    the site is:
    http://www.casasassolo1713.com
    Thanks a lot
    khoand Friend
    #420039
    Could you give me username+password of your backend? I will check it.
    khoand Friend
    #420052
    You check your site again. I enabled Sample Data-Article category.
    loci Friend
    #420156
    ok
    i have understand how can show the module…but i have the problem with the content module…
    • why does it show any featured article in Ita homepage?
    • what i need to enable to see the content for the english site?
    • why in english page i can see only the main menu?and not the Englih menu?
    thank
    loci Friend
    #420202
    Hello
    anyone can help me please?
    thanks a lot
    khoand Friend
    #420264
    Because You publish Chi siamo ENG, Eventi e consigli ENG, Dove siamo ENG, Contatti e Prenotazioni ENG (2) menu items in Main menu(page 2)
    loci Friend
    #420329
    i have made a test:
    if u change the type of menu, of the default page in the main menu, from featured article of all category to single article and select the featured article this is show but with another CSS style.
    maybe this can tell u something
    thanks a lot again
    loci Friend
    #420582
    Hi do u have any news?
    please let me know
    thanks a lot again
    bye
    khoand Friend
    #420610
    I need username+password of ftp to find down what happened?
    khoand Friend
    #420910
    I can’t find down what problem is. You try upgrade your joomla to version 1.7 and ask joomla developer at joomla’s forum. Because I guest prolem is configuration of multilanguage. It’s not bug of joomlart products.
    Salve loci
    Per poter avere un sito multilingua prima devi installare le lingue di cui hai bisogno
    le tue sembra siano inglese francese e spagnolo e sono gia installate
    poi in gestione lingua contenuti devi creare ex novo le 3 lingue inglese francese e spagnolo
    abilita il plugin language switcher
    dopo vai in in menu e crei 3 nuovi menu inglese francese e spagnolo
    una volta creato il primo ES Inglese all’interno del menu crea una nuova pagina Es chiamala Home
    sulla destra clicca sulla stellina sotto la scritta HOME comparirà una bandierina inglese
    ripeti questo per tutti e tre le lingue
    una volta fatto questo vai in gestione template Ja_Travel
    Tab Profili e crea 3 nuovi profili inglese francese e spagnolo
    vai su ogni profilo e alla voce menu type seleziona nel caso di esempio inglese salva
    vai su page assignments e seleziona sulla sinistra il menu inglese a destra come profilo assegna inglese
    ripeti questo per tutte le lingue
    passo finale
    crea un nuovo menu italiano ripeti tutti i passi descritti per le altre lingue
    una volta creato il profilo italiano assegnagli come menu main menu ( all’interno del profilo )
    vai nel menu italiano e la home che hai creato nel menu clicca su sospendi ( non deve essere pubblicata ) ed in page
    assignments dovrai assegnare la Home del main menu al profilo Italiano
    se hai fatto tutti questi passi avrai il sito in 4 lingue
    loci Friend
    #421032
    Ok thanks a lot i will ask to joomla forum.
    But why the title of “Appartamento Bologna ” is black that originally was Purple like the color beside????
    have u modify something?
    thanks a lot bye
    loci Friend
    #421041
    ciao pavit
    grazie mille per la spiegazione
    il problema è che non mi si visualizzano solo gli articoli in evidenza in ogni relativa homepage…tutto il resto è corretto.
    se cambio il tipo di menu da “articoli in evidenza di tutte le categorie” a “articolo singolo” lo visualizza con ultro formato.
    non riesco a capire
    grazie ancora
    Alla voce di menu lingua hai assegnato il menu corretto per ogni lingua ?
    Mi spiego meglio nella home del menu inglese come lingua devi assegnargli inglese
    loci Friend
    #421051
    si chiaro
    lingua inglese e pagina predefinita…
    quello che mi lascia titubante è il fattto che cambiando il tipo di menu articolo viene visualizzato.
    grazie
This topic contains 17 replies, has 3 voices, and was last updated by  loci 13 years, 2 months ago.
