  • mberwing Friend
    #198128
    I have installed the new JA Appolio version 1.1.0 that supports Joomla 3.3.0 as per the blog
    http://www.joomlart.com/blog/news-up…07798-28845289
    I have then followed the instructions for multilanguage on http://help.joomla.org/files/EN-GB_multilang_tutorial.pdf
    and created for Bonus Menu four new menus and associated modules for the 4 languages I need and renamed “Bonus Menu” to “Bonus Menu ALL”.
    But I am confused as I do not know the position I need to select where the Bonus Menu is placed on the homepage.
    As per the quickstart template, the main menu is on position “off-canvas” while for the Bonus Menu there is no module defined.
    However in the template manager under tab “navigation” the Bonus-Menu-ALL is selected for the megamenu and is visible on the homepage when I switch between the languages.
    But I have four different translations for the Bonus Menu but can only select one menu in Template Manager.
    So how can I achieve that I can use megamenu for Bonus Menu and have all four different languages available ?
    Radonja Djurisic Friend
    #536535
    Hello mberwing
    did u look for tutorial for multilingual here ?
    http://www.joomlart.com/documentation/other/joomla-support-faqs
    also pankajsharma will help u with that in
    http://www.joomlart.com/forums/topic/no-module-displayed-on-homepage/
    Tolja
    mberwing Friend
    #536573
    thanks a lot for the link to the documentation.
    I have indeed not created the Appolio styles for the new languages and completed that right now as per the instructions.
    But what I have not found is where to set the Multilingual setup in JA T3v2.
    The documentation says that with the T3v2 framework, I would need to create new profile for each language, choose menu for such profile and assign it to each language respectively.
    I can see in documentation the configuration from the image but do not know how to navigate in my backend.
    Can you please point me to the right direction where I need to do this.
    #536691
    mberwing Friend
    #536697
    This is exactly the link I followed but as mentioned in my last update I do not find the place in backend as per the image:
    Can you please tell me how to navigate in Joomla 3.3 backend to this place
    1. jat3
    #536698
    look in template manager
    also if u cant find please PM me login details so i can guide u better
    Tolja
    mberwing Friend
    #536970
    Have sent you login credentials via PM …. simply cannot find it as screenshot was from older version and Joomla 2.5 most likely but not from 3.3.
    #537005
    i sent u pm ..
    i cant access page
    #537298
    i just saw
    Everithing is fine
    u did all steps to make your website multilingual
    u are using latest T3 framework
    that image is explanation for older version
    so no wary
    Tolja
This topic contains 9 replies, has 2 voices, and was last updated by  Radonja Djurisic 10 years, 5 months ago.
