test melih
 melih
  • Pankaj Sharma Moderator
    #968328
    You have to use different template style for different language so u can select Different Mega menu .
    For off-canvas menu create different menu module and published them for different language menu items .
    like One off -canvas menu module for EN only . and other off-canvas menu module for different language menu items .
    WS Friend
    #968410
    Hi Pankaj,
    Thank you for your advice.
    I have created different menu modules for different languages. To make things simpler I’ve created multilanguege verisons of the section menu (sidenav). Unfortunately it doesn’t work for the mainpage. But if you choose one of the main menu tabs (new post, videos, photos), the side menu works correctly and displays the proper languege version.
    Could you possibly take a look what might be wrong. I’m trying to solve it for an almost one week – and with no results. 🙁
    #968416
    Video menu is not using EN language : http://prntscr.com/ci7knp
    You have to create separate template style for each language and select the menu items from settings : http://prntscr.com/ci7k8e
    One template style for EN language menu items that use only EN language menu in it .
    one for PL language .
    WS Friend
    #968443
    By creating separate style you mean duplicating the template and assigning different language to each?
    #968446
    Yes each template style for each language . And there u can select the different menu for that template style .
    WS Friend
    #970200
    I’ve managed to assign the section menu to the proper language version. However I’ve got still difficulties in assigning the main menu. I’ve created different menus and modules for different language versions. Then I’ve assigned the proper main menu version to the template. Unfortunately the website still does not display the language-version menu. Could you give me an advice what is wrong? 🙁
    WS Friend
    #970236
    OK, I think I’ve solved it. I’ve assigned every language version template as default for its language.
This topic contains 7 replies, has 2 voices, and was last updated by  WS 8 years, 4 months ago.
The topic ‘Multilingual – problem’ is closed to new replies.
