  • vivaldo moscatelli Friend
    #975398
    Hi all I’m experiencing some problem with multilingual; I activated the two plugins and placed language switcher and activated but I can’t see the flags… Can you please help?
    Thanks Vivaldo
    Did you created languages menus ?
    For instance if you have installed english and Italian language you will need to create a menu where the Home menu item should have assigned as default language the Italian language.
    If you are having problems you can share as private reply a temp super user account to your backend and i will have a look at it for you.
    Hope it helps
    #975493
    Please double check the account provided , it doesn’t works
    #975596
    The credentials are good now… sorry and thank you…
    Vivaldo
    I enabled the System – Language Filter plugin – now flag is showing and you will need to create and assign modules to each specific language
This topic contains 5 replies, has 2 voices, and was last updated by  pavit 8 years, 3 months ago.
