  • zandercent Friend
    #118692
    I understand it is possible to have multiple header modules for different pages by copying the module.
    However, when I copy the module, and change the image source location – it still shows the same images as the original module.
    the problem is only apparent when in flash mode (not javascript)
    any ideas anyone??
    argonx Friend
    #214684
    <em>@zandercent 7681 wrote:</em><blockquote>Hi,
    any ideas anyone??</blockquote>
    I am having same problem.
    As soon i transfer to java script it works fine and new pictures are showing..
    Anyone else had same problem?
    aboutall Friend
    #214755
    mod_ja_header with Flash don’t work in Opera 9.10 Build 8679.
    joarvat1 Friend
    #214883
    Yes, I’m having the same problem. It’s a shame, because I would prefer the use the Flash mode – it is smoother.
    Khanh Le Moderator
    #214893
    Hi all,
    I have made a quick update for this module to fix the problem when using multi JA Header instances with flash mode. Please download the attachment and update your system (you could upload to your server to over-write the current JA Header module files).
    1. mod_ja_header.zip
    kgalyen Friend
    #226873
    Thanks! I just was looking for a fix for this and downloaded it. Works like a charm! 😀
    zandercent Friend
    #227205
    Thanks matey.
    good things come to those who wait, and who are listened to by helpful people on this forum!!
This topic contains 7 replies, has 6 voices, and was last updated by  zandercent 17 years, 5 months ago.
