anaivelisse Friend
anaivelisse
- May 2008
- 18 times in 1 posts
July 18, 2008 at 2:00 pm #131029My dabadase crashed and I need help to repair thta table. How can I do that….
This is the message I’ve got::eek:
jtablesession::Store Failed
DB function failed with error number 1194
Table ‘jos_session’ is marked as crashed and should be repairedMenalto Friend
Menalto
- May 2007
- 531 times in 361 posts
July 18, 2008 at 2:26 pm #260748You have phpmyadmin? If so its easy
Login to phpMyAdmin
1.select the database.
2.In the main window you see all tables. Check the boxes next to the tables you need to repair.
3.At the bottom of the window right below the end of the tables there is a drop down menu. Choose “Repair Table”
This should hopefully fix it, if it does, remember to do a BACKUP….anisjolly Friend
anisjolly
- April 2008
- 96 times in 55 posts
July 18, 2008 at 2:32 pm #260749Hi ana
Login to your site’s hostname. it should be something like mysql.thenameofyoursqlhostname
If you do not know how to do this, log into PHPMyAdmin and find the database and the table you’re having problems with.
once you can see the table structure, there will be a menu option called ‘Operations’ (in fact there will be 2 – one at the top and the bottom).
click on Operations and there should be a link on the page called ‘Repair Table’.
That should do the trick for you.
However, before you do this, please backup you database (even if one of the table’s is not working), just in case anything goes wrong with the repair.
Hope this helps.
anisjolly Friend
anisjolly
- April 2008
July 18, 2008 at 2:33 pm #260750Menalto –
You beat me to the answer again!
I gotta type faster!
anaivelisse Friend
anaivelisse
- May 2008
July 19, 2008 at 3:20 pm #260850Now I have this
jtablesession::store failed
DB function failed with error number 1054
Unknown column ‘client_id’ in ‘field list’ SQL=INSERT INTO jos_session ( `session_id`,`time`,`username`,`gid`,`guest`,`client_id` ) VALUES ( ‘6d8df70df65b4b2b498788e0968ec45e’,’1216480621′,”,’0′,’1′,’1′ )
What should I do?mcseller Friend
mcseller
- June 2006
- 4 times in 1 posts
July 19, 2008 at 4:19 pm #260852Hi ana,
can you reach your database by internet?
anaivelisse Friend
anaivelisse
- May 2008
July 19, 2008 at 4:29 pm #260855Yes, I can.
Can you help me?
mcseller Friend
mcseller
- June 2006
July 19, 2008 at 4:35 pm #260857what kind of try have you done at the present?
anaivelisse Friend
anaivelisse
- May 2008
July 19, 2008 at 4:37 pm #260858I tried to repair, to create a new one and to upload a back up with no success…I am about to drop it
mcseller Friend
mcseller
- June 2006
July 19, 2008 at 4:38 pm #260859and, please, say me what version of joomla you installed…
p.s.
try to understand I don’t speak/write English well 😮anaivelisse Friend
anaivelisse
- May 2008
July 19, 2008 at 4:42 pm #260860Actually, English is not my first language. I am using J 1.5.0.
mcseller Friend
mcseller
- June 2006
July 19, 2008 at 4:45 pm #260861Ana I also need to know if the crash has come after you installed any component/modules/plugin. If you did not install/modify nothing if you want you can send me by pv a text copy of your db so I can test this night.
anaivelisse Friend
anaivelisse
- May 2008
July 19, 2008 at 4:50 pm #260862Mcseller-
The last thing I did was updating the Teline II template with the new version (1.4). After that, everything was OK. When I checked the site the next morning I got the message that the “jos_session” chrased. I have two db back ups. One is about three weeks old and one from today (even with the error). Can I send you the two files?
mcseller Friend
mcseller
- June 2006
July 19, 2008 at 4:54 pm #260863I can not promise nothing but I can tell you I will try this night. Send me those files!
anaivelisse Friend
anaivelisse
- May 2008
July 19, 2008 at 5:02 pm #260864Can you send me an email. The text is too long for PM’s.
This topic contains 16 replies, has 4 voices, and was last updated by anaivelisse 16 years, 6 months ago.
