  • komboelijah Friend
    #164626
    Ja- Teline IV
    My front page layout has been altered. some modules are not in the same position that they were.
    the page seems to be elongated, with unnecessary space.
    please please kindly assist.
    thanks in advance
    gray Friend
    #393773
    Not sure it’s possible to help without additional information.
    If the template’s files have not been modified (hacked) just re-install the template to get initial look. Modules will remain the same as before reinstall.
    Phill Moderator
    #393777
    Please go into the template manager and set css and js optimization to “No”.
    komboelijah Friend
    #393819
    the url of the website is http://newfaceofkenya.org/
    komboelijah Friend
    #393820
    will the content that i have added be removed?
    komboelijah Friend
    #393821
    Just did that, though it hasnt changed anything…
    the page still looks disarranged. but the other pages look okay, its just the frontpage.
    Phill Moderator
    #393824
    Please clear all the Joomla caches then we can look again. Have you installed or updated anything before this happened?
    komboelijah Friend
    #393829
    thank you. But how can i restore the same. Can you help me to restore but leaving the module contents?
    komboelijah Friend
    #393830
    I was updating an article, then i refreashed the homepage to see the changes. – unfortunately not the changes that i had expected.
    i cleared the cache after it happened.
    Phill Moderator
    #393836
    Which article? What happens if you unpublish that particular article?
This topic contains 10 replies, has 3 voices, and was last updated by  Phill 13 years, 6 months ago.
