Viewing 15 posts - 1 through 15 (of 30 total)
  • muthumbi Friend
    #730413
    I would like to know why the site will not display well on mobile phones, i have done alot of changes and may be someone can helpme see the problem. Am using Ja-University
    this is the link http://www.africanmemorablesafaris.com/amemsafaris
    muthumbi Friend
    #747253
    Am sure this has everything to do with css on mobile layout, but i have no idea how to change. Infact, how do i view the mobile layouts on the frontpage someone please help.
    The account provided when you opened this topic is not valid
    Send me a new account for your backend via Private Message so i can take a look at it
    muthumbi Friend
    #747257
    Thanks for reply, pavit i have sent the credentials. thanks.
    Please verify again because the one you sent me are the same of this topic and them doesn’t works
    muthumbi Friend
    #747265
    pls check inbox again Pavit
    <em>@muthumbi 490144 wrote:</em><blockquote>pls check inbox again Pavit</blockquote>
    I was able to access backend thanks
    First to go ahead to check what is wrong on your website , i strongly recommend to update :
    1) Your T3 Framework plugin
    2) Your template version
    Both of them are very old versions , so update them using the Ja Extension manager component , ( you need to download and install it )
    We will check again your website after you updated it
    P.S.
    First to make any update take a backup of your website , better if you backup it using Akeeba Backup
    muthumbi Friend
    #747274
    thanks for the message, i have already upgraded t3 and template to the latest. Please check. I also still see sameproblem on phone.
    You need to update template version to 1.0.3 please use Ja Extension Manager to update it , the component will tell you the exact version to download
    muthumbi Friend
    #747522
    <em>@pavit 490167 wrote:</em><blockquote>Hi
    You need to update template version to 1.0.3 please use Ja Extension Manager to update it , the component will tell you the exact version to download</blockquote>
    hi Pavit,
    this is what the one i updated to reads
    Template Information
    Name:
    Ja University T3
    Version:
    1.1.3
    Released Date:
    08 July 2015
    Author:
    JoomlArt.com
    Congrats! You are using latest version of Ja University T3!
    Your version is 1.1.3
    I am wondering how you recommended version 1.0.6
    thanks.
    The account you provided here doesn’t works anymore , i cannot login on your backend , please double check it
    anyway there is already an opened ticket for this thread Ticket Id is TLO-343-21933 , as soon Joomlart developers will be available next Monday they will take a look at it , please restore again backend account
    Best regards
    Ninja Lead Moderator
    #747641
    <em>@muthumbi 490033 wrote:</em><blockquote>I would like to know why the site will not display well on mobile phones, i have done alot of changes and may be someone can helpme see the problem. Am using Ja-University
    this is the link http://www.africanmemorablesafaris.com/amemsafaris</blockquote>
    In this case, I need to check the configuration from backend site, but when I login with username/password of your site but I got this bug
    You need to fix this bug first, then I will help you further
    muthumbi Friend
    #747673
    <em>@Ninja Lead 490785 wrote:</em><blockquote>In this case, I need to check the configuration from backend site, but when I login with username/password of your site but I got this bug
    You need to fix this bug first, then I will help you further</blockquote>
    thanks Ninja, for the help, I think you went through the wrong link, it should be http://www.africanmemorablesafaris.com/amemsafaris/administrator/
    then login with the details i have sent in your inbox.
    #747689
    I checked on templates/ja_university_t3/css/custom.css file and saw some custom work on your site which causes the conflict and that’s reason why your site does not work with responsive mode
    .container {
    width: 1230px;
    .navbar {
    width: 1250px;
    text-align: centre;
    margin-right: auto;
    margin-left: auto;
    + Topbar menu needs to be hidden on mobile layout
    + Add that menu into sidebar with off-canvas position
    muthumbi Friend
    #747727
    With the container width, i really need it to be wide like it is. If i set it to be 1250px, will it affect the mobile layout?
    the top menu is an added module from my side, how am i supposed to hide it from mobile view coz i cant see where to edit. Also how do i asign it to off-canvas and still show it as it is on desktop view?
    thanks
This topic contains 29 replies, has 3 voices, and was last updated by  Ninja Lead 8 years, 9 months ago.
