  • sagacasa1 Friend
    #919581
    my top home 1 no work, the title is on top and not change the image…
    any solution?
    website> http://www.eltijuanense.com/index.php
    Could you describe your problem adding more details ? are you saying you cannot change your logo image ?
    Also edit your post and add a temp super user account to your backend so we can take a closer look at your configuration.
    sagacasa1 Friend
    #919663
    the featured slider not work ..
    the title appears above the image .
    and the slider not play
    1. da21ea103cb939bb9af8707e50f6abfb
    Hi there
    To look correctly at it i will need of a temp super user account to your backend
    sagacasa1 Friend
    #919744
    sagacasa1 Friend
    #919763
    I changed a lot of things on your website , we discussed via Skype about improvements for it.
    It works as should now
    Best regards
    sagacasa1 Friend
    #919824
    tnks for u support, u are big!
This topic contains 8 replies, has 2 voices, and was last updated by  sagacasa1 8 years, 8 months ago.
