Pankaj Sharma Moderator
January 13, 2016 at 5:26 pm #846900Hi
I checked your site and found some issue : http://prntscr.com/9pnmt6
Please remove any redirection if you added on htaccess .
I need to check your site backend for gathering more information and debug .Kindly post your site super user admin details via Private reply (set as private reply) . So i can check the problem .January 13, 2016 at 7:01 pm #846938This reply has been marked as private.Pankaj Sharma ModeratorPankaj Sharma
January 14, 2016 at 4:08 am #847369Hi
Your site is installed on a child directory and this may effect to loading images Kindly assign the site to a domain and check this problem of images.
+ Make the /log folder permission writable .
let me know if it helps.January 15, 2016 at 4:39 pm #848845I cleaned up my domain include subdomains and scanned for the external links but I found nothing. I hope you can confirm that.
So – my problems are still the same.
January 15, 2016 at 4:42 pm #848848Hi
Kindly submit the details below via private reply option .
Domain name :
super user admin user details :
FTP details of site . I will check it .January 15, 2016 at 4:55 pm #848863This reply has been marked as private.Pankaj Sharma ModeratorPankaj Sharma
January 15, 2016 at 5:08 pm #848896Hi
the site is still in the child directory .
Kindly assign a domain or subdomain on the site
currently its http://www.your site .com/frauenhaus/
its should be http://www.your site .comJanuary 15, 2016 at 5:25 pm #848909This reply has been marked as private.Pankaj Sharma ModeratorPankaj Sharma
January 15, 2016 at 6:17 pm #848940Hi
I spent a lot of time to debug this issue , and this seems to be issue from the server and your Joomla ,
images does not getting / in the url so they are not appearing , i turned off SEF url and now u can see it turn back and images showing now .January 15, 2016 at 6:29 pm #848951Oh god, that is really embarrassing me. I would itself need to know, but I think I was routine-blind.
I hadn’t thought of that.I thank you very much nevertheless for your realy rapid response.
Sorry!!
This topic contains 10 replies, has 2 voices, and was last updated by miciba 8 years, 10 months ago.
The topic ‘Navbuttons and popup images will not be displayed’ is closed to new replies.
